Bluetooth SDK Forum Discussions
WeLi_2041066
First like given
I try to use a low power node to send temperature data.
I use "Code-Examples-BT-SDK-for-ModusToolbox-1.3\CYBT-213043-MESH\apps\demo\mesh\sensor_temperature".
I adjust poll_timeout to 600, I think that mean device will wakeup after 1 min.
It is very hard to build a network.
The first problem after I successfully build the network is
When the device sleep timeout It will stuck in "mesh_state_changed_cb:LPN_SCAN: scan:0"
below is the message from UART (blue is I push the user botton, red is after time out).
\0setup nvram ids: net_key_max_num:4 app_key_max_num:8 nvm_idx_seq:3fd0 3fd2-3fff cfg_data_len:192
Mesh Start
## mesh_application_init free_bytes:13000 ##
mesh_application_init: provisioned GATT DB status:0
ds1:0x00501400, len:0x0003cc00
ds2:0x0053e000, len:0x00002000
Active DS:501400 vs1:500400 vs2:501400
thermistor_read high:3254 low:1981 cal:6426
Pub value:71 time:4296002
company_id:ffff opcode:52
ignored
***** Free mem after app_init:11328
mesh_publication_callback: idx:0 company_id:ffff model_id:1100 period:0000
Sensor data send period:0ms
sensor restart timer period:0
mesh_publication_callback: idx:0 company_id:ffff model_id:1101 period:0000
mesh_state_changed_cb:LPN_SCAN: scan:1
mesh_state_changed_cb:LPN_FRIENDSHIP: established:0 addr:5/0
mesh_state_changed_cb:LPN_FRIENDSHIP: established:1 addr:5/5
mesh_state_changed_cb:LPN_SLEEP: timeout:56000
Mesh Start
thermistor_read high:3260 low:1985 cal:6423
Pub value:71 time:4296012
ignored
company_id:ffff opcode:8231
mesh_sensor_server_report_handler msg: 112
thermistor_read high:3297 low:1992 cal:6551
thermistor_read high:3313 low:1991 cal:6639
thermistor_read high:3288 low:1990 cal:6522
Mesh Start
thermistor_read high:3262 low:1995 cal:6350
Pub value:71 time:4296006
ignored
DheerajPK_41
Hi WeLi_2041066​,
We are trying to reproduce the issue at our side. We will let you know the update soon.
Thank you for your patience.
Thnaks,
-Dheeraj
