Since my other thread here was closed, this is intended to be a continuation.
DheerajP_41 I have attached some ADB logs from two scan attempts. In both cases, all 4 devices showed up in the app, but in each case at least 1 didn't have an associated name, it just showed the UUID. Looking at the logs, I see that it does properly discover the name, so not sure why it's not showing up in the app.
This is with version v2.1.0 of the wiced bt sdk. I am having much better luck with this version as opposed to the previous version (I think i was using 2.0.0 when I first tried this experiment). With the latest, I was able to eventually get them all to provision properly, although some took a couple attempts.
ispn:40214:1:0
l1:314:1:0
Thank you very much.
In mobile APP GUI: "at-least 1 didn't have an associated name, it just showed the UUID"
In ADB logs: "Looking at the logs, I see that it does properly discover the name"
Based on your test and above observation, I think it can be a mobile app GUI issue.
Or if it takes more time for scanning (extended/active scan) app may skip the name and only get the UUID for making a connection.
But it should not block or disturb any other feature. Otherwise please provide us the information.
We will inform this to our software team to understand the issue.
-Dheeraj
-Dheeraj
