Hello.
Tool: Modustoolbox 2.2
Target: CYBT-413055-02
How can I avoid build error with "undefined reference". I do need "snprintf".
I add #include "stdio.h". What library do I have to add?
- CYBT-413055-02
I don't see any issue when I checked the snprintf in an empty btsdk application for the same platform. May I know btsdk version which you are using? Could you please update to the latest and try?
-Dheeraj
-Dheeraj
Thanks for your reply. It is delayed to test your suggestion due to my business trip.
I could make it with empty project. and snprintf works fine in empty project.
I'll retry again in my target project. Thanks a lot.
