Hi
I am interested in buying some bluetooth modules to make a mesh network, but I have some questions regarding the compatibility of the modules.
I am currently using the CYBT-213043-02 module in ModusToolBox and I am interested in making a connection with another module from the ones they have in stock:
CYBT-413034-02
CYBT-343026-01
CYBT-423028-02
CYBT-353027-02
CYBT-483039-02
CYBT-343151-02
My questions are:
Which module do you recommend to use with CYBT-213043-02?
which module would you spend less development time to make communication between modules?
I hope and can support me
Yes you can try with CYBT-343026.
Why not purchase one of the CYBT-213043-MESH kits? It comes with 4 boards.
Hello ErVe_4649071,
CYBT-343026-01, CYBT-353027-02 and CYBT-343151-02 are CYW20706 based modules while other are CYW20719 based modules. The programming time, efforts required for any of these is almost same. We have all the required documentation available here on community for all these modules. Moreover, CYBT-343026, CYBT-353027 and CYBT-483039 are also supported in Modus Toolbox 2.1.
However, I can suggest you to go with CYBT-343026-01 as you can find multiple information about this module easily on Cypress Community.
Or you can look at Mesh evaluation kit consisting of 4 boards- https://www.cypress.com/documentation/development-kitsboards/cybt-213043-mesh-ez-bt-module-mesh-eval...
Hello SheetalJ_96
Thanks for your help.
I have the CYBT-213043-MESH evaluation kit, but I want to try connecting another module that is different but compatible with the evaluation kit.
Do you recommend the CYBT-343026-01 module for what I am looking to do?
