TaC_4722371
5 replies posted 5 sign-ins First solution authored
Is there any Bluetooth programming guide for BT BR/EDR for audio applications ? Please provide if there's any. I am working using CYW20719B2.
Tamilarasan C.
TaC_4722371
Hi guys,
I found what I was missing out in my code, I was not returning the required return value in the bluetooth management callback.
Tamilarasan C.
DheerajPK_41
750 replies posted 500 likes received 500 replies posted
I would suggest you to refer the readme file of each audio application to know about its programming and testing methods.
I afraid we do not have a specific programming guide for audio applications. I will try to check internally and get back to you if I find any documents.
Are you facing any specific issue in programming audio applications? Please let us know if you find any difficulty in programming.
-Dheeraj
TaC_4722371
Hi guys,
Tamilarasan C.
