Hello
We use CYW20819 in "embedded mode" and we would like to control CYW20819 finely.
For example, we want to set LOCAL_DEVICE_NAME at other than boot/initialize time.
We find wiced_bt_dev_vendor_specific_command() API that sends VS HCI command to CYW20819 and wiced_bt_dev_register_hci_trace() API that register callback for HCI event.
However we could not find the API that enables to send normal (Non-vs) HCI commands.
Does Cypress offers this kinds of API or have the plan to add this function?
I am sorry, it appears that wiced_bt_dev_set_local_name has been erroneously missed from the current version. It will be fixed in an upcomming release of the bt-sdk (probably 2.4). For now, could you please use
extern wiced_result_t BTM_SetLocalDeviceName(char* p_name);
BTM_SetLocalDeviceName("Toshiya-san");
