Hi
I am trying to PUART send data by SPP.
There are some questions about this
1. I use Puart HW Flow Control
but if I use the rx pin as p2, PURAT doesn't work.(RX: P2, TX : P31, RTS: P30, CTS : P35)
The data sheets and EVM Board states that p2 can be used as RX.
2. I know that Modus SDK supports thread/Mutex.
How do I use Thread/Mutex on cyw20706.
I need to use it. bacase during SPP data transmission, the data transmission speed decreases due to UART INTTERUPT.
Thank you
The CYW920706EVB has some hardware limitations as there are pull up/down resisters on the related pins. I used a CYBT-343026 board to test the UART flow control. It works fine on my side.
Please refer to the test project attached.
The P2 should work because we use it on the kit board. Did you configure the pin with wiced_hal_puart_select_uart_pads?
What's the throughput speed you expect?
-> When I used wiced_hal_puart_select_uart_pads(2,31,35,30), Puaart doesn't work.
-> I want SPP transmittion Data from Puart. but it is very slowly
I checked Puart HW flow with your setting.
Thank you
can I also get advice on SPP transmission from Puart???
What's the expected throughput speed? Could the current configuration satisfy it?
