Bluetooth SDK Forum Discussions
KeTa_1341526
5 likes given First like given 10 solutions authored
I am currently evaluating using CYBT-213043-EVAL.
So I'm looking into [Known issues/limitations] in the Bluetooth SDK.
When I checked "5 Known issues/limitations" in [AIROC™ Bluetooth® SDK 4.1.3 release notes], I found the following issues.
[CYBT-213043-EVAL] Lecoc: Intermittently observed bad packets
<Questions>
1. Please provide more details about this issue.
2. Is this issue only with this evaluation board CYBT-213043-EVAL?
     In other words, will it affect the Hardware and SDK of Module (CYBT-213043)?
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
From the description of the release note, the issue is only with the evaluation board CYBT-213043-EVAL. It is caused by the CY serial bridge software.
Owen_Zhang123
I need to check the problem internally.
Owen_Zhang123
