I have a question about the frequency of SCL in I2C Master mode on CYBT-343026-01 (Chip: CYW20706)/CYBT-353027-02 (Chip: CYW20707).
I'm using Modus Tool Box 2.3/BT SDK 3.1.
Using the I2C API as in the community below, I confirmed the waveform on the evaluation board of each module.
- Setting
wiced_hal_i2c_init( WICED_I2C_SDA_I2S_DOUT_PCM_OUT_SCL_I2S_DIN_PCM_IN );
wiced_hal_i2c_set_speed( I2CM_SPEED_100KHZ );
As a result, the SCL frequency is 185KHz with the following I2C settings.
See waveform below (CH1: SCL, CH2: SDA)
It should be set to 100KHz from the above setting, but it is not set.
Why?
Also, I set "wiced_hal_i2c_set_speed" to something other than "I2CM_SPEED_100KHZ". (I2CM_SPEED_400KHZ or I2CM_SPEED_800KHZ or I2CM_SPEED_1000KHZ)
However, all settings are 185KHz.
I have tried CYBT-343026-EVAL and CYBT-353027-EVAL, but both have the same phenomenon.
ModusToolbox Bluetooth SDK
We have found some issues in the I2C and our dev team is fixing it. The fix will be available in the next SDK release.
But for now, I am attaching a workaround code here. Not that it is not the complete fix. Please use it and let us know if you find any issues.
Use I2C_20706_DIV=42 for 800kHz SCL, I2C_20706_DIV=104 for 400kHz SCL, etc.
-Dheeraj
It should be possible to set different SCL. I am not sure what is the actual issue here.
We would like to reproduce the issue at our side and collect more data. Are you using any standard application provided by us? Could you please share your relevant code with us ?
-Dheeraj
It is the same Code as the following Community. (The Slave address has changed.)
In addition, the settings are as follows.
-Setting
wiced_hal_i2c_init (WICED_I2C_SDA_I2S_DOUT_PCM_OUT_SCL_I2S_DIN_PCM_IN);
wiced_hal_i2c_set_speed (I2CM_SPEED_100KHZ);
Could you reproduce this issue on your side?
-Dheeraj
