Dear Cypress
When I tested using Audio_Sink examples in ModusToolbox, I found there is reconnection failure issue to the iPhone.
Please refer to below for detailed test conditions:
- H/W : CYW920706WCDEVAL, iPhone 6s (s/w ver: 15.0))
- S/W : Modus SDK 2.3 & Audio_Sink application
- Test procedure step by step
(1) iPhone connect to CYW20706
(2) iPhone play YouTube music for less than 10 seconds
- In my case, 1 kHz sine wave
(3) iPhone pause YouTube music
(4) iPhone disconnect to CYW20706
(5) Loop again from the above step (1)
But I have observed that iPhone cannot reconnect to CYW20706.
FYI, I attached the BTSpy log and Air log.
It is a log in which the first reconnection succeeds but the second fails.
Could you analysis about this symptom?
Thanks in advance.
