Bluetooth SDK Forum Discussions
anhnhancao
10 sign-ins 5 sign-ins First reply posted
Dear all,
I owned a CYW20721B2 evaluation KIT and want to run A2DP profile on it.
Everything seems to work fine if the device doesn't lose bluetooth connection, then the connection can not be automatically
re-established.
Is there a way to automatically reconnect after disconnection?
I really appreciate for your help.
AnjanaM_61
First comment on KBA 5 questions asked First question asked
If you want to reconnect from 20721 side, Can you try using the below API for reconnection depending upon your application requirement  :
wiced_result_t wiced_bt_a2dp_sink_connect( wiced_bt_device_address_t bd_address );
Thanks & Regards,
Anjana
AnjanaM_61
Thanks & Regards,
Anjana
