Sometimes it became server callback function was not called when MESH packet was received.
It looks mesh library drop the request. What should I investigate in details ?
[Environment]
ModuaToolbox 2.0 (also 1.1)
CYBT-213043-MESH
Mesh_Demo_213043MESH.color_light
Two color light nodes are provisioned this MESH network.
[Log]
COM13log4.txt: NG node
COM14log4.txt: OK node
When the color light server works, the log is as follows:
company_id:ffff opcode:8276
server trans start time:200 target:5137 present:5137 state:21fb58
server trans target:5137 present:5137 start:5137
transition next state:2
server 21fb58 state:2 remain:200 start:5137 target:5137 present:5137
light hsl srv msg:65
light hsl srv set present light:18349 hue:40593 sat:49971 remaining time:100
set brightness:6
set brightness:218
set brightness:49
When this issue occurred, the log is as follows:
i.e. the callback function which is set by wiced_bt_mesh_model_light_hsl_server_init() is not called.
Could you let me know how to fix or investigate this issue ?
ispn:40214:1:0
l1:314:1:0
- bt mesh
- color light
- cybt-213043-mesh
- mesh
- mesh_demo_213043mesh.color_light
- modustolbox
- modustoolbox 1.1
- modustoolbox 2
Hi Mizuno,
I couldn't duplicate the issue either with android app or meshclient (windows).
I am going through the logs which you have provided. I will give you my feedback soon.
Could you please check and confirm that you are using the latest BTSDK in the ModusToolbox2.0 ?
I am testing in wiced_btsdk <version>2.3.0.5811</version>. (see version.xml of wiced_btsdk).
Thansk,
-Dheeraj
