Unleashing the potential of combining Smart I/O and SPI
RodolfoGL
250 solutions authored 250 sign-ins 5 comments on KBA
Greetings, tech enthusiasts!
Today, I invite you on a journey into the captivating world of embedded systems, where we'll explore a fascinating yet underrated aspect of the latest PSoCTM family of devices. Picture this: a block called Smart I/O, quietly hidden away amidst the excitement surrounding the beloved Universal Digital Blocks (UDBs). But let me tell you, my friends, the Smart I/O block holds immense potential and deserves our attention.
In this blog post, we'll uncover the hidden capabilities of Smart I/O and its remarkable synergy with the Serial Communication Block (SCB). Together, they empower us to create new digital interfaces that may not be native to the PSoCTM platform. Yes, you heard it right! By combining Smart I/O with the Serial Peripheral Interface (SPI), we can unlock a realm of possibilities and enable unconventional digital interfaces that were previously beyond reach.
So first, let’s review what is inside of the Smart I/O block and how it is connected to the SPI interface.
Smart I/O elements + SPI block
The Smart I/O has two major components:
  • 1x Data unit (DU): consists of a simple 8-bit datapath. It is capable of performing simple increment, decrement, shift and AND/OR operations.
  • 8x Lookup table (LUT): consists of a three-input LUT and a flip-flop. The inputs can be the DU output, any of the SPI signals (SCK/MOSI/MISO/SS), any of the GPIOs (A/B/C/D), or any of LUTs output. The logic enforced by the LUT can be sequential (requires a clock) or combinational (no clock).
Note that the direction of the SPI signals depend on how the SPI block is configured – Master or Slave. Basically, the idea is to manipulate the SPI lines to implement a new custom interface. The SPI block works as serializer to push/pull data to/from the CPU.  And the Smart I/O can delay or change the behavior of any of the SPI signals to conform with the new desired digital interface.
In the next sections, you can find some examples.
Inter-IC Sound (I2S)
The I2S is a serial bus interface standard used to connect digital audio devices together. It is very similar to the SPI in terms of clock and data, however it requires a continuous flow of data and the word select signal to indicate if the data is left or right.
The I2S frame has the following format:
Signal
Word 0
Word 1
Word 2
Word 3
Word 4
SD
(data)
16 or 32-bit value
16 or 32-bit value
16 or 32-bit value
16 or 32-bit value
16 or 32-bit value
WS
1 : Left
0 : Right
1 : Left
0 : Right
1 : Left
The following signal mapping is established between SPI and I2S signals.
SPI signals
I2S signals
SCLK
SCK
MOSI
SDO
MISO
SDI
SS
WS
  • I2S Master
 Summary:
The SPI clock and data can be directly mapped to the I2S clock and I2S data. However, the SPI slave select has to be translated to the I2S word select. For that, the Data Unit is configured to toggle every 64 or 32 cycles, depending if the I2S word width is 32-bits or 16-bits, respectively.
The I2S sample rate can be calculated as:
Note that in the example above, the SPI MOSI signal is mapped to the I2S SD signal, which can be an input or output, depending if the I2S FIFO is configured as RX or TX. In case the I2S SD is configured as an input, it should be mapped to the SPI MISO signal.
SPI Config:
Mode: Master
Sub mode: Motorola
SCLK mode: CPHA = 0, CPOL = 1
Data rate (kbps): 3072 / 2048 / 1024 / 768 / 512 / 256
Oversample: 4
Bit order: MSB first
Rx/Tx data width: 16 bits
SS polarity: Active low
Clock: 4x the data rate
SPI time diagram
I2S time diagram
Smart I/O Config:
Data unit:
Input: LUT1 (reset) / LUT2 (enable)
Opcode: Increment and wrap
DATA0: Constant 0
DATA1: DATA Register
Register value: 63 or 31
Size: 6-bits or 5-bits size/width operand
LUT0:
Input: Chip 0 (SPI.mosi)
Mode: Sequential (gated) output
Logic: Input = Output
Output: I/O 0 (I2S.sd)
LUT1:
Input: Chip 3 (SPI.ss)
Mode: Combinational output
Output: Logic to reset DU
LUT2:
Input: Chip 2 (SPI.sclk)
Output: I/O 2 (I2S.sck)
LUT3:
Input: DU / LUT3
Logic: Toggle when DU asserts
Output: I/O 3 (I2S.ss)
Clock:
Same clock as the SPI
 Example:
You can find an example of an I2S Master implementation using SPI + Smart I/O here (configured as TX):
https://github.com/Infineon/mtb-example-psoc6-smartio-i2s
  • I2S Slave
 Summary:
The I2S slave implementation with SPI + Smart I/O is relatively similar to the I2S master. The two major differences are:
1)        The SPI shall be configured as slave
2)        The logic to map the SPI.SS to I2S.WS is different. When the WS signal toggles for the first time, the SS should be asserted and stay asserted.
Example:
There is no example available to demonstrate this interface. If you are interested to find a solution for the I2S Slave, please contact Infineon or leave a message in this blog post.
Serial General Purpose Input/Output (SGPIO)
The SGPIO interface is a four-signal bus defined in the SFF-8485 standard. It is typically used in the backplane controllers to control LEDs and check the disk drive status. Each drive requires 3-bits in a SGPIO frame. The SGPIO master is known as SGPIO initiator and the SGPIO slave is known as SGPIO target. The interface has the following signals:
  • SClock: clock signal driven by the SGPIO initiator
  • SLoad: indicates the beginning of a frame. It can also contain some vendor 4-bit value (L0~3). It is driven by the SGPIO intiator
  • SDataOut: serial data output bit stream driven by the SGPIO intiator
  • SDataIn: serial data input bit stream driven by the SGPIO target
The SGPIO frame has the following format:
Signal
Bit0
Bit1
Bit2
Bit3
Bit4
Bit5
Bit6
Bit7
Bit8
Bit9
SLoad
1
L0
L1
L2
L3
0
0
0
0
0
SDataOut
ODN 2
OD0
0
OD0
1
OD0
2
OD1
0
OD1
1
OD1
2
OD2
0
OD2
1
OD2
2
SDataIn
IDN
2
ID0
0
ID0
1
ID0
2
ID1
0
ID1
1
ID1
2
ID2
0
ID2
1
ID2
2
Drive
Drive 0
Drive 1
Drive 2
The following signal mapping is established between SPI and SGPIO signals.
SPI signals
SGPIO signals
SCLK
SClock
MOSI
SDataOut
MISO
SDataIn
SS
SLoad
  • SGPIO Target
Summary:
The SGPIO Initiator implementation is very similar to the SPI Master when using the submode – TI (Start Coincides), which generates a pulse on the beginning of every word. If using a frame with 4 drives (or 12-bit frame), there is no need to even use the Smart I/O.
If more than 4 drives is needed, the Smart I/O can be used to generate the SLoad signal based on the SPI.SS signal.
SPI Config:
Mode: Slave
Sub mode: Motorola
SCLK mode: CPHA = 0, CPOL = 0
Data rate (kbps): 1000
Bit order: LSB first
Rx/Tx data width: Depends on number of drives. It is usually 12 or 16-bits.
SS polarity: Active high
SPI time diagram
SGPIO time diagram
Smart I/O Config:
Data unit:
Input: LUT5 (reset) / 1’b1 (enable)
DATA0: Constant 0
Register value: 255
Size: 8-bit size/width operand
LUT0:
Input: I/O 0 (SGPIO.SDataOut)
Output: Chip 0 (SPI.mosi)
LUT1:
Input: Chip 1 (SPI.miso)
Output: I/O 1 (SGPIO.SDataIn)
LUT2:
Input: I/O 2 (SGPIO.SClock)
Output: Chip 2 (SPI.sck)
LUT3:
Input: I/O 3 (SGPIO.SLoad) / LUT6 / LUT5
Logic: Asserts the SPI.ss based on SGPIO.SLoad and if SPI.clk is toggling
Output: Chip 3 (SPI.ss)
LUT4:
Input: LUT2 (SPI.clk)
Logic: Delay SPI.clk
Output: None
LUT5:
Input: LUT2 (SPI.clk) / LUT4 (Delay SPI.clk)
Logic: Detect a falling edge on SPI.clk
Output: None
LUT6:
Input: DU / LUT3 (SPI.ss) / LUT5
Logic: Asserts when SPI.clk is running
Output: None
Clock:
Example:
You can find an example of an SGPIO Target implementation using SPI + Smart I/O here:
https://github.com/Infineon/mtb-example-psoc6-smartio-sgpio-target
  • SGPIO Initiator
 Summary:
Example:
The example that shows the SGPIO Target implementation uses the SGPIO Initiator (without Smart I/O). If you need an example of the SGPIO Initiator that supports more than 4 drives, please contact Infineon or leave a message in this blog post.
Management Data Input/Output (MDIO)
The MDIO is a PHY management interface to read and write the PHY control and status registers. The interface has two signals:
  • MDIO interface clock (MDC): clock driven by the MDIO Host
  • MDIO data: bidirectional, where the MDIO host and MDIO interface might drive the bus, depending if it is a read or write frame
The MDIO frame has the following format:
PREamble
Start bits
Operation bits
PHYADR
DEVTYPE
TA
ADDR/DATA
32 bits
2 bits
2 bits
5 bits
5 bits
2 bits
16-bits
All 1s
0 0
0 0: Addr
0 1: Write
1 1: Read
1 0: Read+Addr
0x00
to 0x1F
0x0: Reserved
0x1: PMD/PMA
0x2: WIS
0x3: PCS
0x4: PHY XS
0x5: DTE XS
W: 1 0
R : Z 0
Any 16-bit value
The following signal mapping is established between SPI and MDIO signals.
SPI signals
I2S signals
SCLK
MDC
MOSI
MDIO
MISO
MDIO
SS
Not used
  • MDIO host
Summary:
When using the SPI to implement the MDIO host, you have to short externally the MOSI and MISO lines. When sending a whole frame, you need to write 4 words to the SPI TX FIFO:
1)        0xFFFF (first preamble word)
2)        0xFFFF (second preamble word)
3)        Write: 0xXXXX (00 + 00 or 01 + PHYADR +  DEVTYPE + 10
Read: 0xXXZZ (00 + 11 or 10 + PHYADR + DEVTYPE + 11
4)        Write: 0xXXXX (the address or data value)
Read: 0xFFFF (dummy word)
The usage of the Smart I/O is optional when implementing the MDIO host.
SPI Config:
Mode: Master
Sub mode: Motorola
Data rate (kbps): 4000
Enable MISO late sampling: true
Rx/Tx data width: 16-bits
SPI time diagram for MDIO Write or Address frame
SPI time diagram for MDIO Read or Read+Address frame
Smart I/O Config:
The Smart I/O usage is optional to implement the MDIO host. It might be used to add some delays in the signal to conform with the MDIO specification, if required.
Example:
There is no example available to demonstrate the MDIO host with SPI. If you are interested to find a solution for the MDIO host with SPI + Smart I/O, please contact Infineon or leave a message in this blog post. If you can use a PSoC with UDBs, you can find the MDIO host implementation with UDBs in this post:
https://community.infineon.com/t5/Resource-Library/MDIO-Interface-Component-for-PSoC-6/ta-p/250038
  • MDIO interface (slave)
 Summary:
We recommend use the UDBs to implement the MDIO interface. It is not possible to use SPI + Smart I/O to implement a fully functional MDIO interface. You can find the MDIO interface UDB implementation in this post.
List of PSoCs that has the Smart I/O
As we conclude this exploration, remember that the power to innovate lies within each of us. With products like PSoCTM and its incredible Smart I/O block at our disposal, we have the means to create new digital interfaces that were unthinkable. So, go forth, my friends, and let your creativity soar as you embark on your own ventures in the captivating realm of PSoCTM and Smart I/O. The possibilities are endless, and the future is in your hands.
Happy tinkering, and until our paths cross again in the vast world of technology, keep pushing the boundaries and unlocking new frontiers! 😉
