Nisshinbo Micro Devices and Infineon produce the world’s smallest class radar module - a non-contact, high-precision radar solution 60GHz radar smart sensor micro module. The standard module for Nisshinbo Micro Devices's 60GHz radar sensor module is a turnkey solution that consists of a modularized microcontroller PSoC™ 6 with Infineon's XENSIV™ "BGT60TR13C" MMIC. It provides a total solution including not only hardware but also software, and can be used for applications such as human detection and access control.
What is behind this solution and how it supports our customers, that is what we want to talk about.
Together we make the IoT work.
