In the previous session, we learnt about Digital Peripherals on PSoC 6 and how you can interact with them using the HAL, the PDL, and the BSP.
In this session, we are going to introduce you to the industry-leading capacitive touch sensing solution, CapSense. You will learn how to build basic CapSense Applications in Modus Toolbox using the CapSense Middleware Library. This session has interesting demo projects at the end to get started with building your own CapSense application!
The exercises created as part of this training series have been tested to work on the following boards. The exercises might need minor modifications if being used for a different board.
The presentation used in the video is attached to the blog. Jump to 1 : 43 s in the video to get started with the session.
The training material and exercises are hosted here: ModusToolbox Training Session 3 Github Repository
Feel free to drop in your queries in the Infineon Developer Community.
