Security Bulletin: Public Statement on Bluetooth SIG Member Statement on Bluetooth Impersonation Attack (“BIAS”) Inquiries CVE-2020-10135
MichaelF_56
250 sign-ins 25 comments on blog 10 comments on blog
Introduction
The Bluetooth SIG has issued a statement regarding Bluetooth security vulnerabilities outlined in the research paper from the École Polytechnique Fédérale de Lausanne and captured in CVE-2020-10135. The following summarizes the SIG recommendations in the statement, and Cypress’ response:
SIG Recommendation
Cypress Response
Use the Secure-Connections-Only mode
All Cypress-provided Bluetooth firmware supports Secure-Connections-Only mode
Use a software stack that addresses CVE-2019-9506
Cypress software has resolved CVE-2019-9506 (see below for firmware versions)
Do not use the authentication-complete HCI event (or equivalent) in a host or application to affect any change in security role or access level by a remote authenticated device
Cypress-provided Bluetooth firmware does not use the authentication-complete HCI event to affect security role or access level changes
In addition, Cypress’ Bluetooth firmware provides the following:
  • Requests for role change during secure authentication will result in authentication failure
  • Because initial privacy settings are stored in device NVRAM, any subsequent attempt to change security levels are rejected
For further questions, our customers can create a support case through our secure support portal or by contacting their Cypress representative.
If you believe you have identified a vulnerability in any Cypress product, please visit our security response page and email the Product Security Incident Response Team (PSIRT) at psirt@cypress.com.
The below and subsequent firmware versions resolve CVE-2019-9506:
Part Number
Firmware
ModusToolBox BT SDK
CYW20706A1
BCM20703A1_001.001.005.0405.0000
*N/A
CYW20719B1
*N/A
CYW20721B1   *N/A
CYW20719B2
CYW20719B2_002.003.026.0112
BT SDK 2.5
CYW20721B2 CYW20721B2_002.003.026.0115 BT SDK 2.5
CYW20819A1
CYW20819A1_001.002.012.0131
BT SDK 2.5
CYW20820A1
BT SDK 2.5
CYW89820
BT SDK 2.5
CYW20706A2
BCM20703A2_001.002.011.0330
BT SDK 2.5
CYW20735B1
CYW20735B1_002.002.008.0086
BT SDK 2.5
CYW20702A1
BCM20702A1_001.002.014.1524.0000
*N/A
CYW43012C0
CYW43012C0_003.001.015.0168
BT SDK 2.5
CYW4339
BCM4335C0_003.001.009.0171.0000
*N/A
CYW4349B1
BCM4349B1_002.002.014.0142.0000
*N/A
CYW4359D0
CYW4359D0_004.001.016.0150.0000
*N/A
CYW43455C0
BCM4345C0_003.001.025.0162.0000
*N/A
CYW4343W/CYW43438
BCM4343A1_001.002.009.0118.0000
*N/A
CYW4354A2
CYW4354A2_001.003.015.0109.0000
*N/A
CYW4373A0
CYW4373A0_001.001.025.0064.0000
*N/A
*Delivered upon request. Please contact your local Cypress FAE.
2 Comments
