Cypress is aware and has analyzed the vulnerabilities associated with the recently released KRACK attack (https://www.krackattacks.com) against implementations of the Wi-Fi WPA2 security.
Official details of the vulnerability are tracked via a number of Common Vulnerabilities and Exposures, or CVEs. CVEs can be looked up at https://cve.mitre.org.
