A variety of classic forms of interaction with equipment exist. In the olden days, we used to have wired telephones on our desks, and when they rang, we'd pick up the receiver. Picking up the receiver accomplished several things: it stopped the ringing, connected us to the caller, and informed the caller you had picked up the receiver. All you needed to do was say 'hello' to begin the call. But, we no longer live in those simple times. Nowadays, you will have to locate the cell phone, pick it up, add a fingerprint, look at the screen, swipe or touch at the right place, then visually check it to make sure you have done it correctly. This, of course, follows only if you did not accidentally disconnect your call when you pulled the cell phone out of your purse or pocket.
One thing that always interests me about a new piece of equipment is how easy it is to operate. To me, and maybe you could relate as well, a mechanical on/off switch has a beautiful simplicity, and there is something satisfying about pressing the switch, hearing the click, and seeing the light on. This now brings us to the topic of a product's interaction with the real world and its users, which is absolutely crucial for the product. Interaction can be motion, lights, audio, displays, and inputs. Inputs are often mechanical buttons and switches, but I am about to show you an even more interesting way produced by Infineon.
Infineon CAPSENSE™ technologies can be used to detect the position or motion of many items – from fingertips to metal plates. CAPSENSE™ can replace mechanical switches and position sensors in many consumer, commercial, and industrial products. Thus, the possibilities are limitless.
Now, do you happen to have a great idea on how you can interact with a piece of equipment? Infineon and Hackster.io are presenting a design challenge for you. For more information, take a look HERE. In the end you could win free development kits and other great prizes.
Best of luck!
