NOR: Securing Embedded Systems with SEMPER™ Secure NOR Flash
BushraH_91
750 replies posted 50 likes received 250 solutions authored
As devices and applications become more and more connected, embedded systems memory architecture is evolving to address the heightened focus on security. At the same time, next-generation System-on-Chips (SoCs) are migrating to advanced technology nodes that do not support embedded nonvolatile memory. The alternative – standard external flash devices – are easy targets for cybersecurity attacks. As a result, these SoCs require Flash memory solutions that prioritize security, reliability, and safety.
SEMPER™ Secure NOR Flash was designed with these changing requirements in mind. A hardware engine accelerates encryption to protect stored data without a performance penalty. It also features a hardware root-of-trust to enable highly-secured end-to-end transactions, and performs diagnostics and data correction for functional safety.
To learn more about secure design principles and to discover Infineon’s SEMPER™ Secure product line, please read our whitepaper:
 “Securing Embedded Systems with Semper™ Secure NOR Flash”
If you have any questions, please feel free to respond below and a member of the team will reach out to you.
