How to enable BTSpy traces in your BTSDK application
lock attach
DheerajPK_41
750 replies posted 500 likes received 500 replies posted
BTSpy is a trace utility available in Modustoolbox that can be used in the BTSDK platforms to view protocol and generic trace messages from the embedded device. Here, I will show you the quick steps to enable the BTSpy traces in your application which will help you while debugging your application.
Step 1: Include header files
Step 2:  Variable definitions
In this step, we define the required macros, configure the transport configurations, etc.
Step 3: Initialize and Register callbacks
In this step, we initialize transport configurations, buffer pool and register a callback function to send the traces over transport.
Step 4: View Traces
Program the application to your platform and BTSpy & ClientControl tools available in the IDE/SDK. BTSpy listens on the UDP port 9876 and can receive a specially formatted message from ClientControl. Sample traces will look like as below.
Note:
  • Add below line to the makefile to launch the tool from IDE CY_BT_APP_TOOLS+=BTSpy ClientControl hello_client
  • Please find the attached sample application and logs.
FYI. Listed few useful links
https://github.com/Infineon/btsdk-utils/tree/master/BTSpy
https://github.com/Infineon/btsdk-host-apps-bt-ble/tree/master/client_control
https://github.com/Infineon/CypressAcademy_BT101_Files/blob/master/PDFs/WBT101-05-Debugging.pdf
