Translation_Bot
100 likes received
Dear Infineon engineer.
I want to use TLE7386-3E chip to generate 5V, 3.3V, and 1.3V voltages. However, in my design, it's not for MCU. Therefore, for the pins related to reset, RO_1, RO_2, and the pins related to watchdog, WDI, WDO, can I just give them a constant high or low voltage level? That is, I don't need these monitoring functions, as long as the chip can generate voltages normally.
Your help with this matter is invaluable to me, and I thank you in advance.
Doublemint
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86IC/about-TLE7368-3E-watchdog/td-p/741135
