AnyCloud SDK
austin_h
New Contributor II
Can AnyCloud SDK (MQTT sample code)connect to Google Cloud Platform??
I am confused after studied GCP IoT Core guide information.
https://cloud.google.com/iot/docs/how-tos/getting-started
Should GCP iot device sdk need to port on  PSoC 6 +WiFi platform??
https://github.com/GoogleCloudPlatform/iot-device-sdk-embedded-c
Austin
AditiB_81
I'll check with the internal team and will revert back.
Aditi
Sharn-Lin
New Contributor
Hi Aditi,
As my understanding the current lib: aws-iot-device-sdk-embedded-C it customize for AWS cloud connect and tested.
from the link  https://github.com/GoogleCloudPlatform/iot-device-sdk-embedded-c
Modus may need to integrate new iot sdk lib like above link for google cloud platform connect, it may like modus did for Azure as below, or just little bit code change/config on aws iot sdk let it support google cloud. could you please help check it
Sharn
