Hi, I created a new app using the anycloud wifi server template, and flashed it on both of my dev boards. I only changed the SSID and password variables.
Problem on my CY8CPROTO-062-4343w:
- After switching to the right wifi, I can open the website in my browser and play with the slider or capsense to change brightness. This works maybe 5-10 times, after that there is no change in the PWM value, and on serial I get the error message:
"Error: Updating event stream failed" What might be the reason for this?
Problem on my CY8Kit-062-Wifi-BT:
- I used the library manager to update the board type.
- Compiles without errors and flashes
- I get the message on the TFT and serial that the Wifi connection to my home network has been successful.
- After that message: Nothing, however I can see that the device acquired an IP address. Trying to open port 80 results in a "permission denied" error, so the networking seems to work but the server does not accept connections on port 80.
I am not very experienced in using Modus Toolbox and the whole PSoC ecosystem, so I bet that I configured something wrong. Anyone with ideas on how to approach debugging this? Does the code example runs stable on your end?
Thanks!
ModusToolbox AnyCloud SDK
We tried the above example at our end on both the kits but we couldn't reproduce the issue.
Regarding "Error: Updating event stream failed" What might be the reason for this?" -> you can reload the HTML page and see if it works.
Also, you can change the buffer size of char sensor_value_buffer[SENSOR_BUFFER_LENGTH] inside the void server_task(void *args) function under server.c file. Currently the size of SENSOR_BUFFER_LENGTH = 128, you can try to increase the size and check if that works.
Regarding "Nothing, however I can see that the device acquired an IP address. Trying to open port 80 results in a "permission denied" error, so the networking seems to work but the server does not accept connections on port 80." -> Can you please try some other device maybe a mobile phone instead of a PC to perform this exercise?
Let me know your observation.
May I know if you have done any changes to the code?
If yes, then please let me know.
Hi, no I did not change anything except the wifi AP name and password as recommended on Github.
