I have created a cypress docker image which has all dependencies required to run my UI tests.
However when I am running my image in GitLab pipeline it gives following error:
As per error it looks like it is trying to download dependencies again though I have provided everything in Dockerfile and downloading during docker run is actually not required.
This is happening in GitLab pipeline only other wise Docker run is successfully running when executed outside GitLab pipeline. Requesting you support to identify and resolve the problem.
Hi @rkcypress
I think you are in the wrong community forum. There's a thin line between Cypress, an Infineon Technologies company that provides embedded solutions, and Cypress.io which is a software company that provides testing solutions. The query you have seems to be directed at Cypress.io and here's the link to their forum: https://www.cypress.io/support
Hi @rkcypress
