skruglewicz
50 sign-ins First like received 5 solutions authored
I trying to connect to my my home router I follow the instructions on the GitHub readme.me
I'm getting the following error:
Function whd_wifi_join failed at line 1622 checkres = 33555456
Connection to Wi-Fi network failed with error code 0x2000400. Retrying in 5000 ms. Retries left: 119
my router is set to:Router Security as WPA2 Personal
The secrity type in the file configs/wifi_config.h is set as follows:
#define WIFI_SECURITY CY_WCM_SECURITY_WPA2_AES_PSK
here is the error in the terminal screen.
Could anyone give me some insight into what could be wrong?
Any help will be appreciated
Getting an error connecting to the WIFI
Hello
Your correct. problem solved . I'm connected to my router now.
#define WIFI_SSID "MY_WIFI_SSID"
"MY_WIFI_SSID" had 2 characters in the wrong case!
The security type default in the file configs/wifi_config.h is set correct and works .It was not the connection problem
Thanks for your help
Steve K
Rakesh_BG
50 solutions authored 100 replies posted 100 sign-ins
Hi @skruglewicz
I tried Anycloud MQTT client example on CY8CPROTO-062-4343W Kit.
Able to connect to router with properly configured SSID and password.
Got error similar to your case when the SSID or password is wrong.
Please verify the credentials of the AP in wifi_config.h and try.
* Macros
/* SSID of the Wi-Fi Access Point to which the MQTT client connects. */
/* Passkey of the above mentioned Wi-Fi SSID. */
#define WIFI_PASSWORD "MY_WIFI_PASSWORD"
If still problem persists try with other access point .
If still the problem doesn't gets solved we will look again.
Hello
Steve K
