Antenna tuners Forum Discussions
HansKofod
First question asked Welcome!
For a low power application (RX) will the device function below 600MHz - or in other words are there any significant functional loss when operating at lower frequencies - at very low powers?
Fully understand that the device is not characterised at these frequencies, and that we will have to do that ourselves.
Ishrat
First solution authored First reply posted Welcome!
Thank you very much for showing interest to our devices. Usually this device can perform well even below 600 MHz but  to answer your question properly, I would like to know exactly which frequency range you are planning to use and would be also helpful to know the application of this device as well.
Thank you and best regards,
Ishrat Mahbub
Application Engineer
Ishrat
Ishrat Mahbub
