I will use an FPGA to configure a BGSA144ML10.
Is my understanding of the configuration phase correct when I do not want to use triggers?
1. Set register 0x1C = 0x00 to power up the tuner
2. Wait 50ns
3. Set register 0x1C = 0x80 to disable the trigger mask 0
4. Set register 0x00=desired switch setting which will make the tuner reconfigure the path immediately.
5. Repeat step 4 with new setting when desired.
If I want to use a trigger:
2. Wait 50ns
3. Set register 0x00=desired switch setting which will configure the shadow register only.
4. Set register 0x1C = 0x01 to set trigger0 which will make setting active.
5. Clear trigger setting by setting register 0x1C = 0x00?? Or is it cleared automatically?
6. Repeat from step 3 with new setting when desired.
Thanks in advance!
ispn:42861:1:0
l1:33:1:0
l2:1362:1:0
Hi @George_T,
I have you been able to find find any information about the configuration procedure?
BR,
Jonas
Hi @jonkar,
Please reply privately with the more details so the discussion can be moved to a private channel.
Thanks and regards,
George
Hi @jonkar,
Locking this thread as the discussion is moved to private channel.
Thanks and regards,
George
