Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
Translation_Bot
To be able to read the data from the register, the default value should be a forward increase of 0, and the flip starts and decreases at 7ffF, but even if you take the register value to 1, it's 128 °/s to calculate it. I don't think this value should be correct and I want to ask about the calculation method in this regard
Translation_Bot
Hello @fsaaan
It's not “the angular velocity calculated by the TLE5012B-E1000 is incorrect”; it is likely that the external motor speed is insufficient to reach its minimum resolution. Try updating the environment. If you have any questions, just keep replying to this post.
Best,
Julis
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E8%A7%92%E5%BA%A6-%E7%A3%81%E6%80%A7%E4%BC%A0%E6%84%9F%E5%99%A8/TLE5012B-E1000%E7%AE%97%E5%87%BA%E7%9A%84%E8%A7%92%E9%80%9F%E5%BA%A6%E4%B8%8D%E6%AD%A3%E7%A1%AE/m-p/671927
Translation_Bot
Hello @fsaaan
Best,
Julis
