Inductor and Diode current Calculations for Dual Boost PFC
dev_ss
First solution authored 5 sign-ins First like given
Hi All,
I am stuck with PFC design, can you please suggest any design document for Inductor Current calculations of Dual boost PFC Converter using Bridge.
regards,
ShifangZ_26
10 likes given 250 sign-ins 1000 replies posted
Infineon High efficiency 3kW bridgeless dual boost PFC evaluation board, this evaluation board shows how to design a high power density 3kW 90kHz bridgeless dual boost power factor correction (PFC) boost converter working in continuous conduction mode (CCM). More details information could be found in the link: https://www.infineon.com/cms/en/product/evaluation-boards/eval_3kw_db_pfc_c7/
If you click the Application Notes of this Eval board, you will get details calculate formula for Inductor Current Calculation. LINK: https://www.infineon.com/dgdl/Infineon-EVAL_3KW_DB_PFC_C7-AN-v01_00-EN.pdf?fileId=5546d4625e37f35a01...
btsshirt
First reply posted Welcome!
Hello, I was using a TOSHIBA VFS15 Inverter with an IGBT module FP15R12W1T4 inside. After more than 4 months of smooth operation, the inverter unit suddenly blows up. Upon further inspection, I find that the diode (on the S and T terminals) has also blown, and the pin even appears to be shorter than typical. Let's talk about the possible causes of the blown diode. I wasn't entirely confident that I could repair this inverter with a brand-new IGBT module before I knew exactly what had caused the explosion.
ShifangZ_26
Kieran_Pan
First question asked 100 replies posted 50 solutions authored
You could know more from our design guide for Boost Type CCM PFC from the following link:
https://www.infineon.com/dgdl/Infineon-Design_guide_boost_type_CCM_PFC_ICE3PCSxx-AN-v02_00-EN.pdf?fi...
Kieran
