Hi Folks,
I am working on ICE2HS01G , half bridge LLC Controller, I have connected the circuit as p0er the reference design. However, I am unable to get Vref of 5V at pin 9. I am giving a Vcc of 13V, internally vreg of 5v and Vdd should be generated as per the data sheet, but I am facing issue there. Because of it there is no 4V on ENA pin and no output on Lg and HG pins.
Please guide if any one had faced similar issue.
Thank you
Hi @dev_ss ,
According to your description, the IC appears never be actived. When powerup, have you observed the voltage on Css (or SS pin) with an oscilloscope?
May I know which Evaluation Boards as your reference, and could you provide your schematic for us?
Neo
Hi Neo,
I have checked voltage on SS pin across Css, it is 0V . I am refereing following application note by Infineon. https://www.infineon.com/cms/en/product/evaluation-boards/eval_2kw_48v_char_p7/.
According to schematics I have probed across C65 on page 49.
Hi @dev_ss ,
Sorry about the late reply.
The peak voltage of Vss is about 1.8V, almost reaches the internal 2V reference voltage. The duration is around 5ms? I guess. At the very least, this proves that the chip is indeed trying to startup.
The datasheet has the following descriptions about soft start:
1) Soft start is implemented by sweeping the operating frequency from an initial high value until the control loop takes over. This initial switching frequency should be high enough so that the resonant current at first pulse can be limited within the desired value.
So, it's recommended that you do not set the initial frequency too low, please check whether the following resistors are reasonable: Rfmin, Rtd, Rocp and Rreg.
2) According to the description in the green box, OCP protection is unlikely to occur in your application, will other protection be triggered? Please confirm it.
3) What about the VINS pin? If the voltage on VINS pin is lower than the threshold Vinson, IC will never start normally.
Neo
Hi Neo,
Thanks for response. The following are the values I have connected. These are as recommended from application note.
Rtd = 270k
Rfmin = 27K
Rocp = 6.2K
Rreg = 3.3K
The Vins is around 4.5V.
I am unable to understand the fact that why Vref of 5V is not getting generated, as it is guaranteed by the design. i am geting 0V at Vrefg pin too.
Hi @dev_ss ,
You are right. Refer to the block diagram, when an appropriate voltage is applied to VCC pin, the internal 5V0_REG will start, and the corresponding 5V appears in Vref Pin.
I think the voltage on Vref Pin appeared briefly, otherwise, it is impossible to explain the pulse voltage on SS Pin.
Can you confirm that the onboard ICE2HS01G is a good one? Ever tried replacing it with a new one?
Neo
Hi Neo,
I have checked IC from pin to pin with multimeter it didn't show any short with ground. Do know if there is any testing circuit to check the working of IC or any SOP?
As Vref is not getting generated it is quiet possible that Vdd supply is also not getting generated, which is i/p to almost all the internal circuits of IC.
Hi @dev_ss ,
We don't have such testing circuit to offer.
Here is a ICE2HS01G 400V in/12V&25A out online simulation module for your reference:
I'm still working on it to figure it out.
Hi Neo,
Thanks for your contribution. I was able to operate the IC using DC biasing.
Thank you,
