I would like to know the possibilities of LLC topology in charger applications.
In the whitepaper at the following URL, there is a description of the main LLC position, but it is not mentioned in the topology comparison in Table 1.
Can someone add LLC to this table?
- LLC
Hello ,
LLC topology in USB-C charger applications, if your question is based on USB-C power adapter (Since you are referring whitepaper of USB-C page, I guess you are looking for this), LLC topology is not the best topology, since USB-C power adapter is wide and dynamic output requirements, for example, fixed voltage of 5V, 9V, 15V, 20V, 28V, 48V, and SPR range 3.3V -31V with 10mV units per step, EPR range with 20mV units per step. If LLC topology have to selected, the output need additional DC/DC transfer for USB-C requirements. For 65W -240W, Infineon will update it by end of Nov, and PFC + Hybrid Flyback, PFC + Active-Clamp Flyback will be introduced.
For feedback of adding LCC introduction in write paper, we will feedback to owner of this documentation. Please kindly subscribe this documentation.
Lisa
Hello ,
Lisa
Thank you for your response.
Thank you also for your feedback to the document owner. I will subscribe to this paper.
I also agree that LLC is not the best topology for dynamic output requirements.
Best Regards
Satoshi
