Good morning,
when i'm using the AWS IOT example on PSOC6 (CY8CPROTO-062-4343W) i'm not able to run SNTP.
Apprently the sntp.c is never compiled (when building libraries).
At the end, the linked is invoking an error as it doesn't find the sntp.c functions references.
Do you please have an idea how to enable sntp.c compilation or any other hints to make sntp working on AWS IOT example environnement ?
thanks a lot
ModusToolbox AWS IoT SDK
hello,
i'm succesfully able to use NTP when i'm moving the SNTP directory to my application directory.
The LWIP/Apps is never compiled. It seems there is something to do with the /libs/wifi-mw-core and the .cyignore which is ignoring many directories. I've tried to modify it but without success.
By moving apps/sntp directory (not ideal, but enough for the time being) i'm overcoming the issue...
Which is the example that you are using when you are facing this issue? From where did you get the SNTP library? Correct me if I am wrong but I am guessing you are using Modus ToolBox .
hello,
