Hi All,
I have downloaded aurix development studio and done basic configurations as below
Build Configuration→Set Active→External GCC - Debug.
Properties→C/C++ Build→Settings. Changed the Prefix and Path fields
under the Tool Settings tab
When I try to build the project I'm getting below error
Please help me to resolve this error.
Invoking: AURIX GCC Compiler
tricore-gcc -std=c99 "@C:/PLT_Development/External GCC - Debug/AURIX_GCC_Compiler-Include_paths__-I_.opt" -O0 -g3 -Wall -c -fmessage-length=0 -fno-common -fstrict-volatile-bitfields -fdata-sections -ffunction-sections -mtc162 -MMD -MP -MF"Libraries/iLLD/TC33A/Tricore/_PinMap/IfxEray_PinMap.d" -MT"Libraries/iLLD/TC33A/Tricore/_PinMap/IfxEray_PinMap.o" -o "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxEray_PinMap.o" "../Libraries/iLLD/TC33A/Tricore/_PinMap/IfxEray_PinMap.c"
c:/infineon/aurix-studio-1.9.0/plugins/com.infineon.aurix.tools_1.9.0/build_system/tools/make/sh: tricore-gcc: not found
Building file: ../Libraries/iLLD/TC33A/Tricore/_PinMap/IfxEvadc_PinMap.c
"make --output-sync -j8 all" terminated with exit code 2. Build might be incomplete.
17:58:14 Build Failed. 9 errors, 0 warnings. (took 31s.524ms)
Aurix
This looks like a misconfiguration. From what I understood, you would like to use an external compiler (here the GNU TriCore tools) within the ADS, because you want to use the External GCC Debug configuration.
The error message indicates that still the integrated TASKING tools are used. So you might need to review the configuration of the external GCC tool chain.
Ulrich Kloidt
TASKING tools support
Please check if all steps in the following KBA are followed.
I have followed the steps, but still facing same problem
cctc -cs --dep-file="Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.d" --misrac-version=2004 "-fC:/Deva/TestProj/Test_Workspace/TC332_ADS/Tasking External Compiler/TASKING_C_C___Compiler-Include_paths.opt" --iso=99 --c++14 --language=+volatile --exceptions --anachronisms --fp-model=3 -O0 --tradeoff=4 --compact-max-size=200 -g -Wc-w544 -Wc-w557 -Y0 -N0 -Z0 -o "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.src" "../Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.c" && \
make: *** [Libraries/iLLD/TC33A/Tricore/_PinMap/subdir.mk:75: Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.src] Error 2
if [ -f "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.d" ]; then sed.exe -r -e 's/\b(.+\.o)\b/Libraries\/iLLD\/TC33A\/Tricore\/_PinMap\/\1/g' -e 's/\\/\//g' -e 's/\/\//\//g' -e 's/"//g' -e 's/([a-zA-Z]:\/)/\L\1/g' -e 's/\d32:/@TARGET_DELIMITER@/g; s/\\\d32/@ESCAPED_SPACE@/g; s/\d32/\\\d32/g; s/@ESCAPED_SPACE@/\\\d32/g; s/@TARGET_DELIMITER@/\d32:/g' "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.d" > "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.d_sed" && cp "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.d_sed" "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.d" && rm -f "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGpt12_PinMap.d_sed" 2>/dev/null; else echo 'No dependency file to process';fi
Building file: ../Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.c
Invoking: TASKING C/C++ Compiler
cctc -cs --dep-file="Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.d" --misrac-version=2004 "-fC:/Deva/TestProj/Test_Workspace/TC332_ADS/Tasking External Compiler/TASKING_C_C___Compiler-Include_paths.opt" --iso=99 --c++14 --language=+volatile --exceptions --anachronisms --fp-model=3 -O0 --tradeoff=4 --compact-max-size=200 -g -Wc-w544 -Wc-w557 -Y0 -N0 -Z0 -o "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.src" "../Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.c" && \
if [ -f "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.d" ]; then sed.exe -r -e 's/\b(.+\.o)\b/Libraries\/iLLD\/TC33A\/Tricore\/_PinMap\/\1/g' -e 's/\\/\//g' -e 's/\/\//\//g' -e 's/"//g' -e 's/([a-zA-Z]:\/)/\L\1/g' -e 's/\d32:/@TARGET_DELIMITER@/g; s/\\\d32/@ESCAPED_SPACE@/g; s/\d32/\\\d32/g; s/@ESCAPED_SPACE@/\\\d32/g; s/@TARGET_DELIMITER@/\d32:/g' "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.d" > "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.d_sed" && cp "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.d_sed" "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.d" && rm -f "Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.d_sed" 2>/dev/null; else echo 'No dependency file to process';fi
cctc F100: cannot open "opt-ctc.spec"
make: *** [Libraries/iLLD/TC33A/Tricore/_PinMap/subdir.mk:75: Libraries/iLLD/TC33A/Tricore/_PinMap/IfxGtm_PinMap.src] Error 2
Please check the above error for reference
Ulrich Kloidt
