AURIX™ Forum Discussions
User17486
Hi all,
I added DSPlib to my project, which has many long-named files. After that, the project is not built, error tricore-gcc, e = 87 The parameter is incorrect.
This means that the string with the parameters has exceeded the length of 32k. Is it possible to bypass this limitation?
P.S. I use HighTec toolchain.
Regards, Gennadiy
