AURIX™ Forum Discussions
User16898
Level 4
Level 4
how can I configure Trap handlers?
So far I can see only this in debugger:
3709.attach
I saw that there are some functions in iLLD that handle traps, what is its's class or type:
IFX_INLINE IfxCpu_Trap IfxCpu_Trap_extractTrapInfo(uint8 trapClass, uint32 tin);
void IfxCpu_Trap_memoryManagementError(uint32 tin);
void IfxCpu_Trap_internalProtectionError(uint32 tin);
void IfxCpu_Trap_contextManagementError(uint32 tin);
void IfxCpu_Trap_assertion(uint32 tin);
void IfxCpu_Trap_systemCall_Cpu0(uint32 tin);
How can I use this functions to retrieve information about trap I've enter ?
Working on Tc222L
User16898
Level 4
Level 4
Found the solution,
1. Go to Program Files\TASKING\TriCore v6.3r1\ctc\lib\src
2. run unpack-tc-libc-sources.exe
3. select all files starting with "trap..."
4. copy-paste it somwere to the project and compile.
