robs1
Level 4
Level 4
100 sign-ins 50 replies posted First solution authored
Which are the setting of a PWM counting up and down with trigger of preceding channel??
When I set CM0 and CM1 I have to write dutycycle1/2 and dutycycle2/2? or only duty cycles?
How can I set (line codes) all the counters to start from 0 as starting count point?
Thank you in advance.
Yuva
250 replies posted 250 sign-ins 100 solutions authored
When the channel is reset based on the trigger from the previous channel, the CM1 and CM0 defines the edges within the period.
Yuva
robs1
Level 4
Level 4
Yes, but also for up-down counter?
Yuva
Yes, trigger from previous channels is also applicable in up/down mode. The count mode is changed when the trigger occurs and edges are based on the CM1 configuration, you may refer to Figure 79 UM part 2.
robs1
Level 4
Level 4
ok, thank you.
So I configure CM1= dutycycleinpercentage*Tperiodticks??
