xiaoxuan
50 sign-ins 25 replies posted 25 sign-ins
HI,
I had some problems communicating with flaxray using TC375
The following is the configuration of the frame header. It is normal to configure communication in this way.
ID: 8 Can send data to another controller
ID:9 Indicates that data of another controller can be received
Below I have modified MessageBuffers = 8
so that the controller cannot send or receive data
May I ask what went wrong with my configuration and how to modify it?
Di_W
    for (bufferCount = 0; bufferCount < config->numberOfMessageBuffers; bufferCount++)
        IfxEray_setSlot(eraySFR, config->header[bufferCount], config->data[bufferCount], config->slotControl[bufferCount]);
Xiaoxuan, please refer to above source code in your project.
The IfxEray_setSlot() function is used to configure the message buffer and assign it to a specific slot in the communication cycle.
  • eraySFR: a pointer to the ERAY SFR registers
  • config->header[bufferCount]: the header information for the buffer, as specified in the configuration settings
  • config->data[bufferCount]: the data payload for the buffer, as specified in the configuration settings
  • config->slotControl[bufferCount]: the slot control information for the buffer, as specified in the configuration settings
If you simply modify the buffer number without taking into account the buffer's RAM size, it could result in errors. It's important to review other sections of the source code to ensure that the buffer's RAM is allocated correctly.
Di_W
