AURIX™ Forum Discussions
User16669
why i enable mpu(proten bit in syscon register ),then my program will goto reset?
ScottW
First solution authored First like received 5 sign-ins
There are several possible causes for program reset--more detail is needed. Have you determined which trap is causing the reset? Are you clearing SAFETY_ENDINIT prior to writing to SYSCON?
