AURIX™ Forum Discussions
Manda3
5 replies posted First question asked First reply posted
how to remove read and write protection TC234 for jtag or DAP. Thanks in advance for your help
Manda3
TBencher
First like given 50 sign-ins 10 solutions authored
Hi dilna1, thanks for your request.
Please can you tell me a little bit more about your application and why the controller is read/write protected?
Do you use an application board, a starter kit or a customized board?
Thank you.
Best Regards
Manda3
hello I use customized board
TBencher
Hi Manda3,
I assume this board does not come from yourself?
The reason why I am asking this is, that we don't  support hacking TCs from other companies.
In this case, we would rather recommend you doing a new design with a current TC.
If this board comes from yourself, please attach you schematics. If this information is confidential,
please just send it to info@tbench-solutions.com . We'll take care of it.
TBencher
Manda3
I have it for personal use. I need a read and write Dflash
Manda3
I understand you.Can you recommend me someone who could help me.
Manda3
or is there a development board with this tc243 PG-TQFP-144-27 processor
TBencher
Ok. I would recommend you visiting webshop from HITEX (https://www.ehitex.de) where you can find a bunch of starter kits as well as evaluation boards from the A1G devices to work with. Your particular device is unfortunately not available, but depending on you needs you could chose a slightly higher version and scale it down again if you use your final controller board.
TBencher
