for
please tell me how can i do the same
Aurix
Hi @aurther,
You want to configure SMU Reset Request to trigger a "System Reset" (see screenshot attached of SCU_RSTCON.B.SMU) through Tresos.
To do so, you need to open the Mcu editor in Tresos. In the "General" tab, navigate to the section "McuResetSettingConf" under "McuModuleConfiguration".
In the field "McuSMUResetConf", select "MCU_SMU_SYSTEM_RESET_SEL1" from the sliding menu.
This way, the SCU_RSTCON.B.SMU bitfield will be updated through Tresos.
Hope this helps.
Hi @aurther . Sorry, I don't quite understand the question - Tresos Studio lets you configure the MCAL, and generates code based those settings. It doesn't allow you to add arbitrary register changes outside of the AUTOSAR API.
Hi @aurther,
Hope this helps.
Thanks you @AMG
