do-while
10 questions asked 10 sign-ins 5 sign-ins
Is there no send output function in the illd library, I didn't find it ,Can you remind me if there's something relevant in the Illd library?If there's no content in the Illd library, can you share some demos?🤔🐌
julis
10 likes received 25 solutions authored 100 sign-ins
Hi @do-while
 And we also published SENT demo code on github.
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/iLLD_TC397_ADS_SENT_Redund...
If this answer solved your question, please accept it as solution.
Thank you.
Di_W
You can find the following functions in the SENT drivers provided in iLLD:
  1. IfxSent_Sent_deInitModule
  2. IfxSent_Sent_initChannel
  3. IfxSent_Sent_initChannelConfig
  4. IfxSent_Sent_initModule
  5. IfxSent_Sent_initModuleConfig
  6. IfxSent_Sent_readChannelSerialDataFrame
  7. IfxSent_Sent_readChannelSerialMessageFrame
The code snippet emphasizes the initialization of the SENT module and channels, as well as the handling of interrupts for received data.
julis
Hi @do-while
Thank you.
