do-while
10 questions asked 10 sign-ins 5 sign-ins
我在sent接收的过程中遇到了下面问题
接收的第一帧数据正常,后面接收的数据FIR中断标志位就会置1(This bit is set after a Synchronization / Calibration pulse was received that deviates more than +- 25% from the nominal value. The referring data is ignored.)关于频率我没有找到原代码位置
请解答一下谢谢
julis
10 likes received 25 solutions authored 100 sign-ins
Hi @do-while
1. 确认MCU和sensor设置了相同的tick值,以保证通讯正常
2. 可以示波器重点看下第二帧数据的sync
3. 频率的设置,参考https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/iLLD_TC397_ADS_SENT_Redund...
Best,
julis
julis
Hi @do-while
Best,
julis
do-while
非常感谢
