Hello.
i'm using ADS tool and try to import Infineon Sample code. but below error happen.
please let me know how to solve this.
thank you.
Could you get the example from the below link and import them? https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples
Best Regards.
Best Regards.
hello. i've never used github, so i don't know how to download samplecode files. is there is instruction about using github?, basically i want to ADS works properly. is there any other method to solve this "unreachable" problem?
Could you also check the below thread?
Best Regards.
Hello. i read above link and check my network status, and i get off my VPN and tried it and same error message happen.
what should i do?
Downloading the example from GitHub and importing it into ADS is the best option available now. You can try to follow the instructions from the below link or any other method suggested in google search results to download from GitHub.
https://stackoverflow.com/questions/7106012/download-a-single-folder-or-directory-from-a-github-repo
Best Regards.
