AURIX™ Forum Discussions
E-John
10 replies posted First like given 25 sign-ins
Dear all,
In code base "TriBoard_TC39XB_V1.1.0",
#pragma section syntax below, what does the option "awc3" means?
What documentation can we refer to this section attribute? It is not found in gcc toolchain documentation.
thanks.
#if defined(__GNUC__)
#pragma section ".text_cpu3" ax
#pragma section ".bss_cpu3" awc3
#endif
E-John
It will assign the code section to CPU3 core by setting the "c3" flag.
refer to "19.3.4 Core assignment in the source code" p305 of the document "C:\HighTec\toolchains\tricore\v4.9.3.0-infineon-1.0\docs\userguide.pdf"
this documentation exists after HighTec Free Entry Toolchain is installed
E-John
