AURIX™ Forum Discussions
User14049
Hi ,
I want to move data variable value from one core to another core, can anyone help me how to do that in Aurix
From core0 to core1 and core0 to core2
ScottW
First solution authored First like received 5 sign-ins
In the default configuration, all cores can access each other's RAM (DSPR in the case of a variable) as well as the common (LMU) RAM areas. It should just be a matter of mapping a volatile variable on core1 and core2 to the location in memory where core0's variable is located.
The location of the variable in RAM will have implications with regard to access time, caching, etc. and this must be considered if using the variable in a data-sharing context.
