miniwiggler Reset pin
lior
5 questions asked 10 sign-ins 5 replies posted
hi ,
I try to use with miniwiggler as standard JTAG but I see that if I dont connect the Reset pin it is not succeed to connect.
JTAG standard not include reset pin.
so is it must to use and connect reset pin to miniwiggler ?
Nambi
500 replies posted 50 likes received 5 likes given
1. https://www.infineon.com/cms/en/product/evaluation-boards/kit_miniwiggler_3_usb/
You can see that Miniwiggler supports "20-pin Automotive JTAG."
2. https://www.infineon.com/dgdl/Infineon-AP5600410_DAP_miniWiggler-ApplicationNotes-v01_00-EN.pdf?file... : "Table 1 Automotive JTAG Connector on Target Board". From this table, you can see that RESET is a part of the Automotive JTAG Connector.
Best Regards.
Nambi
Best Regards.
