Feb 17, 2019
08:29 AM
Feb 17, 2019
08:29 AM
I am using AURIX_TC297_TFT and I am having problems with the building.
After following the AURIXâ„¢ Quick Tool Setup Guide and importing the project BaseFramework_TC29xB, when I try to build I get this errors:
Can someone please help me?
Thank you
**** Incremental Build of configuration Default for project BaseFramework_TC29xB ****
make all
Now the make files are generated !!!
Makefile:18: recipe for target '1_ToolEnv/0_Build/9_Make/0_Src.mk' failed
process_begin: CreateProcess(NULL, sh.exe -c "/../php/php /../php/Scripts/IfxSwFw_GenMake_CSrc.php PROJ_DIR= C:/AurixWorkspace/BaseFramework_TC29xB; DEFAULT_TARGET_TYPE= Tricore; SECOND_TARGET_TYPE= ; THIRD_TARGET_TYPE= ; SPECIAL_TARGET_TYPE= Mcs; TOOLCHAIN_FOR_DEFAULT_TARGET= Gnuc; TOOLCHAIN_FOR_SECOND_TARGET= Tool2ndCpu; TOOLCHAIN_FOR_THIRD_TARGET= Tool3rdCpu; TOOLCHAIN_FOR_SPECIAL_TARGET= Gnuc; USE_FILE_PATTERN= ; DISCARD_FILE_PATTERN= ; EXTERNAL_SRC_FOLDERS= ", ...) failed.
make (e=2): The system cannot find the file specified.
make: *** [1_ToolEnv/0_Build/9_Make/0_Src.mk] Error 2
Thank you
Feb 18, 2019
02:03 AM
Feb 18, 2019
02:03 AM
Hi Enricol,
I've ran across this a couple of times. I think what it means is that you may be missing some runtime libraries from Microsoft. You'll probably get a more proper error message when you run the php utility from the command line. It will tell you which dll is missing and you can then look up the installer on the microsoft website.
Note it can be a bit of a puzzle, but eventually you'll strike a homerun. I myself have the following runtime libraries installed:
Microsoft Visual C++ 2010 x86 Redistributable
Microsoft Visual C++ 2010 x86 Runtime
Microsoft Visual C++ 2012 Redistributable
Microsoft Visual C++ 2012 x86 Additional Runtime
Microsoft Visual C++ 2012 x86 Minimum Runtime
Microsoft Visual C++ 2015 Redistributable (x86)
Microsoft Visual C++ 2015 x86 Additional Runtime
Microsoft Visual C++ 2015 x86 Minimum Runtime
But I don't recall which one you actually need, if not all.
Principal Technical Specialist
Embedded Software
After following the AURIXâ„¢ Quick Tool Setup Guide and importing the project BaseFramework_TC29xB, when I try to build I get this errors:**** Incremental Build of configuration Default for project BaseFramework_TC29xB ****
make all
Thank you
Embedded Software
Feb 18, 2019
08:39 AM
Feb 18, 2019
08:39 AM
Running the PHP script from the terminal doesn't provide further information.
I checked and it seems like I have all the libraries installed, but the problem still remains.
Any other suggestions?
Feb 18, 2019
11:24 AM
Feb 18, 2019
11:24 AM
Most redistributable's indeed coincide. What happens when you run, the following from a CMD shell:
php -?
From within the BIFACES framework? Presuming you installed it in the default location, you must first change directory to:
C:\BifacesWin32\Php
If all its prerequisites are in place, then it should list its command line options. If not, then I expect Windows will report a message that it cannot find a certain dll.
If there is nothing amiss with the php utility, then I may have misjudged the error message. You say that you import the project. So that means you're running it from within an Eclipse IDE environment. In that case you must make sure to add the BIFACES bin-utilities to your path environment variable. In the BIFACES root there should be a file called StartBifaces.bat and its contents should be:
@SET BINUTILS_PATH=C:\IFX\BifacesWin32\bin
@SET MAKECMD_WITH_APP=C:\HighTec\ide\eclipse-v1.6.1\eclipse.exe
@SET PATH=%BINUTILS_PATH%;%PATH%
@START %MAKECMD_WITH_APP%
@EXIT
Note that the bin utilities are pre-pended, before the IDE is started. Also note that I replaced the BIFACES IDE with the HighTec IDE, but you needn't necessarily do that.
Embedded Software
Feb 20, 2019
07:57 AM
Feb 20, 2019
07:57 AM
Ok, thank you.
Now I am able to build the project, but when I connect the board it is not recognized.
I tried using DAS Device Scanner but no "TriCore-Family" device is found.
I am using a micro usb to usb cable (it was not provided with the board)... is it okay or do I need some specific cable?
How can I fix this problem?
Feb 21, 2019
12:11 AM
Feb 21, 2019
12:11 AM
enricol wrote:
Ok, thank you.
Connector wise I think you have the correct cable, however you need to bear in mind that some USB cables don't have the data pins wired so they can only be used as a power cable. One way to check this is to connect your board to the USB cable and check if the Windows devices manager enumerates it. You should see a driver popping up called "Infineon DAS JDS DEBUG" as shown in the attached snapshot. If it's not showing then you probably need to look for another cable. The same thing can occur if the board was accidentally bricked, because then it's power will be shutdown briefly after it is reset/connected. I'm guessing that doesn't apply to your case because it's the first time that you're trying to flash the demo application. So I'm only mentioning it to be complete.
Embedded Software
Mar 05, 2019
09:26 AM
Mar 05, 2019
09:26 AM
Thanks, with your help I'm finally able to load code to the board.
My problem now is that I cannot debug correctly. I'm using UDE but I am not able to put breakpoints where I want: only on certain lines (the ones with the small circle on the left) can be associated with breakpoints.
The other lines are also skipped when I execute the step-by-step debug.
Please give me some other useful insights.
Mar 05, 2019
09:48 PM
Mar 05, 2019
09:48 PM
Good to read that you've got things sorted and that you're well on your way. Debuggers, compiler optimisations and compiler debug information, aren't always the very best of friends. With low grades of optimisation stepping your source code is pretty much as expected. However as soon as you start revving the engine, things become complicated. The compiler may for example find a way of re-arranging assembly or conclude that it may be dropped. It may start jump-tailing calls or inline tiny functions. Sometimes it will reverse inline functions for duplicate patterns of assembly. It will also optimise some of your variables into registers such that they no longer exist in memory or on your stack. As soon as that happens there may no longer be assembly associated to a source level step. This is moment when step-markers start disappearing from your debugger view. Or you can't set watches on some of your variables. Or your stacktrace becomes a little harder to trace. So typically higher grades of optimisation are postponed until the release phase and lower levels of optimisation are used during development cycles.
I see you're making use of iLLD sample projects. Try changing (=lowering) `-02` (Config_Gnuc.mk) to `-01` and try again. If it doesn't give you the desired behaviour, drop it even further to `-00`. If yet again still things look rather odd, try changing the definition of IFX_INLINE (CompilerGnuc.h) to and empty one. That should improve things.
Henk-Piet Glas
Embedded Software
Mar 06, 2019
12:56 AM
Mar 06, 2019
12:56 AM
I tried as you said, but changing the level of optimization results in the following building error:
How can I address this problem?
Mar 06, 2019
03:13 AM
Mar 06, 2019
03:13 AM
This problably has the same cause as discussed in this posting. Since those are different tools, rather than looking in Lcf_Tasking.lsl you need apply the offered solution to Lcf_Gnuc_Tricore_Tc.lsl instead.
Henk-Piet Glas
Embedded Software
Mar 07, 2019
02:22 AM
Mar 07, 2019
02:22 AM
Thanks, this solved the problem!
Now, how can I print in the UDE simulated I/O?
If I put a printf in core0_main, the memtool doesn't complete the loading (image below) and when I start debugging the IDE ask me the location of file "vio_virtio.c" and if I give it, the debugging session get stuck into that function.
I searched in this forum but I didn't find any solution.
Mar 07, 2019
02:30 AM
Mar 07, 2019
02:30 AM
Nice one. You'll need to study chapter 5.3 of this application note. Chapter 5.4 subsequently shows how to enable to simulated IO debug window, but I guess you already figured that one out.
Henk-Piet Glas
Embedded Software
Mar 08, 2019
07:37 AM
Mar 08, 2019
07:37 AM
Got it!
The other problem related to debugging that I'm experiencing is that sometimes, when I'm debugging, at a certain time the program stops on the instruction reported below (instead of continuing with the execution):
What is causing it?
What is causing it?
Mar 08, 2019
08:29 AM
Mar 08, 2019
08:29 AM
enricol wrote:
Got it!
What is causing it?
Looks like you're running into a trap. Traps indicate a hardware violation which, in your case, seem to have a spurious nature.
What you have todo is to find out the trap class. Typically trap handlers halt the target by means of a debug instruction (IfxCpu_Trap.c). When that happens you will be able to read its halted vector address from the disassembly window of your debugger. The trap class is then established using the following formula:
class = (trap address - BTV)/32
Where BTV is the start address of the vector table. The trap class, combined with the trap identification number (called TIN) will provide additional hints of what type of error is triggering it. The TIN typically resides in register D15 when the trap handler is hit. You will have to consult table 6.1 of the Infineon tricore architecture manual (volume 1) to find out which specific trap definition has been triggered.
You will also have to try and find out where the PC is located at the precise moment the trap is being triggered. You can do this by consulting the stacktrace window when the trap has been hit. That will give you the precise instruction that causes the trap and combined with the trap definition it should give you a pretty good feel of what's going wrong, and hence how to solve it.
Henk-Piet Glas
Embedded Software
Mar 09, 2019
08:48 AM
Mar 09, 2019
08:48 AM
Besides, do you know if it is possible to use the wake button as a general purpose button? How can I override its ISR?
I checked in the documentation but I wasn't able to find what I was searching for.
Mar 11, 2019
12:49 AM
Mar 11, 2019
12:49 AM
Judging from the PCB schematics and datasheet this is not possible; switch S102 is dedicated to the TLF35584 voltage regulator.
Henk-Piet Glas
Embedded Software
Mar 11, 2019
12:56 AM
Mar 11, 2019
12:56 AM
I thought the same, but I wanted to be sure.
I also wanted to use the iom demo, but it seems like in the folder "iLLD_1_0_1_9_0_TC2xx_Drivers_And_Demos_Release" provided there are some missing files (IfxIom_Iom.h and Iom/Iom/IfxIom_Iom.h).
Do you know where I can find these missing pieces?
Mar 11, 2019
02:39 AM
Mar 11, 2019
02:39 AM
Sorry, I don't. Maybe someone else knows. Alternatively you can run it by your local Infineon representative. Perhaps they can help.
Henk-Piet Glas
Embedded Software
Mar 18, 2019
09:02 AM
Mar 18, 2019
09:02 AM
I sent many email but no one is answering... is there any way you can help me?
I found the attached library but it is related to the hightech toolchain, instead I am using the baseframeworks provided by the myicp webpage.
I tried to port that library to my current environment but ,even if it compiles correctly, nothing works at execution time .
Thanks in advance
Thanks in advance
Jul 22, 2020
02:00 AM
Jul 22, 2020
02:00 AM
I am encountering same problems, anyone could help me with this?
