NourMansour
I am trying to use the assembly functions:
__moveToDataParam0();
__jumpToFunction();
and I get the following error 1 line after the call to __jumpToFunction():
ctc E208: syntax error - token "," inserted before ""
 C/C++ Problem
and I expected this to be an include error and as I traced the functions to file:  IfxCpu_IntrinsicsGcc.h I found that it includes: "machine/intrinsics.h"
which is not found in the demo projects or in the project files. How can I resolve this issue?
Erick_G
100 sign-ins 25 solutions authored 50 replies posted
Hi @NourMansour,
Could you please share more of your code or the part that’s causing the error?
This file is within the compiler files, so it should be located in ....\Infineon\AURIX-Studio-1.9.16\tools\Compilers\tricore-gcc11\tricore-elf\include\machine in the Gcc compiler case, you don’t need it within the project files.
Erick
Erick_G
Hi @NourMansour,
Erick
Thank you for your reply. Now that I understand the file is actually in the compiler files, not the project, I looked for other causes and I found I was missing
#include "IfxCpu_Intrinsics.h"
