AURIX™ Forum Discussions
User16350
i'm currently developing CAN Communication protocol using Multican+. I use loop back mode for testing.
The problem is that message is transmited but never arrive.I try to fix this by turning off nodes RX pins( multican manual recomendation)
and set all nodes to loop back mode. But it doesn't work.
My code is is basing on multican_can.h headher implementation sample( ILLD library )
I couldn't find much about loop back mode and I'm out of ideas what else can be wrong.
microcontroler AURIX TC22
User20349
Hi @ gLukas :- Were you able to solve this issue? I am also trying to configure CAN for loopback mode , transmission is getting completed but no new data received
