interrupt response time
HeShanyuan
Distributor - Weikeng(GC)
10 questions asked 50 sign-ins 25 sign-ins
For TC387, assuming that an interrupt source has the highest priority, from the start of the interrupt request ,through arbitration, responding to the interrupt request, saving CSA register data, storing stack data, until the final PC pointer points to the interrupt function entry address, how many clock cycles are required for the entire process and approximately how many microseconds does it take? Can Infineon provide a method for measuring interrupt response time?
Di_W
To measure interrupt response time, you can use a logic analyzer or an oscilloscope to monitor the time between the interrupt request and the processor's response.
Di_W
